Go Back   VAF Forums > The Never Ending Debate Section > Primers
Old 02-04-2020, 04:40 PM
Ender Ender is offline
Default Anyone using Steward Systems Primer have any updates after flying for a few years?
Like the subject says, anyone that used Ekoprime or Ekopoxy for interior priming have any updates for flying birds?
Building RV-14A
Flight Test Engineer
www.hikebikefly.com
Old 02-04-2020, 05:49 PM
Robin8er Robin8er is offline
Default So far so good
I used stewart primer and paint the exterior. Been flying almost a year now and its held up fine, just as good as any other paint. I used both eko prime and eko poxy for priming, then ekocrylic as a top coat.
My plane has spent some time outdoors, but mostly hangered. I've been happy with it.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 02-04-2020, 06:05 PM
bscycleman bscycleman is offline
I have the same story to report as Robin8er. My plane has been flying almost 2 years and the paint has held up very well. No signs of wear or scratches. It is hanged except for trips and has been out is a couple of storms and flown through heavy rain.
I used Ecoprime on everything inside. On the outside I used Ecopoxy and both the acrylic and poly top coats.
Brian
Old 02-05-2020, 10:03 AM
rag rag is offline
Ekoprime sprayed on all the interior components. 6 years flying. Holding up well, but I have noticed that certain solvents will remove the primer quite easily.
Old 02-05-2020, 10:56 AM
Haven't flown yet, but I used white Ekopoxy for the seat back, the seat floor and the baggage floors. They've been rattling around the shop for months and the paint is unmarred. I'm planning on using a darker shade of it for the remaining interior.
Dave
RV-3B, working on the canopy installation
Old 02-06-2020, 12:02 PM
Rag
Which ones? When did you find yourself using solvent around the plane after it was done?
Building RV-14A
www.hikebikefly.com
Old 02-06-2020, 03:16 PM
EkoPoxy primer on the exterior, covered by EkoCrylic. Two years flying. Airplane always habngared except at Oshkosh. Paint is wearing well, with no obvious defects related to the paint material itself. No bubbling, fading, hazing or similar evidence of failure of the paint.
Old 02-06-2020, 04:06 PM
wilddog wilddog is offline
Have these paints caused any allergic reactions such as rash? SPI epoxy primer worked great but gave me a rash.
Old 02-06-2020, 08:02 PM
No reaction of any sort to the EkoPoxy and EkoCrylic, in my case.
Old 02-12-2020, 02:33 PM
hardegg hardegg is offline
Default Priming - stewart system - ekoprime
So let me ask what is possible a really dumb question(2 part),
I'm assuming the parts are primed completely then riveted together and the subsequent build up between the two parts is not sufficient enough to create problems? Are the rivets left uncoated or do you go back in after the fact and dobb them with primer?
or i could be reading them wrong and it's all primed after assembly.
