Old 02-10-2020, 08:24 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Originally Posted by RV9APILOT View Post
RV7A FLYER was right. I got an ICAO Hex code and got it entered and went for a test flight this morning before the rain came. OKC approach was really busy so I stayed out over Lake Thunderbird and called KOUN (Max Westheimer) and talked to them and they said they were getting my ADSB. I checked the PAPR upon return from flying and it obviously worked, I got the report and forwarded it to Garmin. I'll see what they have to say. Thanks everybody for the information and help!!
If there were no red items on the report, then you've passed. Were there?
2019 Dues paid!
Old 02-11-2020, 04:55 AM
RV10Man RV10Man is offline
There were 2 red blocks, 100% fail. "Bar alt" and the "Geo alt".
We emailed it to Garmin. We know it's probably something in the settings.
RV9A under construction--N781DM reserved
Donated
Old 02-11-2020, 05:42 AM
Walt's Avatar
Walt Walt is offline
Did you perform the calibration the GAE encoder?, Did you have the xpdr checked as req'd?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-11-2020, 06:26 AM
We're in contact with our avionics tech now.
Donated
Old 02-16-2020, 06:57 AM
RV9APILOT RV9APILOT is offline
ADS-B out is working now. Went flying Saturday and OKC approach was getting my ADS-B out. Got home and did the ADS-B performance report and came back with no red boxes. Thanks to all for all the help.
Old 02-16-2020, 10:36 AM
Working well. Have you perhaps also considered adding ADS-B In? It's nice, on the Dynon Skyviews, to get current TFR's and weather reports showing up on your screen in writing, as well as rain, at various airports., that are current and usually only 4 to 10 minutes old. Plus all the air traffic around you shows up on your screen, direction, distance from you, N number, elevation above or below you, etc. Very handy to have if you are in Veil C airspace of B class airports.
https://flightaware.com/live/flight/N159MA
Old 02-16-2020, 05:22 PM
I have considered ADSB in. Was going to go with Garmin GDL39, it would work with my AERA 660 or tablet. Although there are lots of options out there for ADSB in.
Old 04-16-2020, 06:37 PM
FasGlas's Avatar
FasGlas FasGlas is offline
To the OP. Today I took my plane up to test a newly install ADS-B out. I was a distance away from PHX approach at 9500', I called to ask for an ADS-B check. Approach gave me a squawk code then came back saying they show my Xponder but no ADS-B. I flew a bit more towards PHX but no ADS-B. Came back to base... A few hours later I went online to see if there was a report... Sure enough, there was a report and the ADS-B passed (no red). All the flight info was there and right... SO... I don't think I would always trust the controller
Beech D17S Staggerwing
Lancair 360
Cessna 120
A&P IA
Old 04-20-2020, 07:40 AM
n82rb's Avatar
n82rb n82rb is offline
one thing on the 335, if you turn the transponder on with the on button. you may get a red block on the alt. alwas turn it on with the alt button.
bob burns
RV-4 N82RB
Old 04-20-2020, 08:44 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
FWIW: Controllers are there for traffic control so they only see what their "sector" feeds them the instant they look at it. The only way to 100% check for ADS-B compliance is the on-line report as you did. Anything else will be "hit and miss".
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
