Old 06-19-2018, 07:11 AM
BMC_Dave BMC_Dave is offline
Default WTB #6 Nutplate Jig
Just seeing if anyone has a nutplate jig they don't need anymore. Looking for the #6 kind, thanks
Old 06-19-2018, 08:20 AM
RV6_flyer's Avatar
I have one nutplate jig. It works on #6, #8, and #10. IF you are using Mil Spec nutplates, they should all have the same leg size. Look at measurement J on the linked page.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-19-2018, 09:05 AM
Yeah I'm using K1000-06s mainly, PM'd with info.
Old 06-19-2018, 09:11 AM
RV Jerry RV Jerry is offline
Cleco nutplate upside down in pilot hole and then drill hole thru legs, as good as any jig and you can cleco multiple nut plates in , goes a lot faster.
Jerry Scott
Rocket II
Old 06-19-2018, 09:33 AM
I feel like I tried this and it wasn't ideal but I can't remember specifically. Hmm...
Old 06-20-2018, 08:46 AM
Marc Bourget Marc Bourget is offline
If you cleeco the nutplate to use it as a jig, then use a small of drill as possible to avoid losing center tolerance. If your trying to match holes, say for AD-4 rivets, better to drill 1/8" and use a rivet for location - it's much more concentric.
I'd approach the nut plates the same way.
Onward and upward
Old 07-06-2018, 02:29 AM
pfjay52 pfjay52 is offline
what size cherry max rivets (counter sunk) does everyone use to attach nutplates? i'm away from home and putting together a Spruce order, can't remember what i use
cheers,
Phil
