I'm on the fence about installing the purge valve control although I do have the purge valve which came mounted to the engine. I know that there are methods of starting a hot engine other than the purge valve but wondered if anyone else has been in the same position but installed the control later? Or is the afp system designed around the purge valve? Looking for opinions.
