At Sun 'n Fun when the three Judges were inspecting my plane one of them said "Can you reach that fire extinguisher back in the baggage compartment in case of an inflight emergency?" I was somewhat trapped but I said "yes" thinking if there is a fire I would get it someway. Regardless, it was not a good situation which I am sure cost me points but even worse it is an unnecessary risk. I had been carying one in the side pocket but the top came off while it was rattling around in there with the flashlight extra batteries, miniature chocks and rudder gust lock pins/RBF Flag (they are held on with internal plastic tabs - Halon RT A600 in the Aircraft Spruce catalog). Anyway after conceptualizing placement I decided that between the seats would be best. I made a little aluminum box type pedestal 1.625" high mounted it on a plate with flush screws from the bottom (into platenuts) and mounted the plate on the control tunnel cover with the existing screws. Worked out very well.
Bob Axsom
Bob Axsom
