Cruising at 3000'msl 5450 RPM 5.5 gals an hour. Lower RPM means lower gals per hour!
Thanks for the info!
So…one guy told me 5140 rpm (about 21MAP) produces 4.5 gph. That sound right? (for planning).
Thanks again.
Look in the POH. Should be listed there after initial flight test determines the numbers for your aircraft.
Howard,
I get 4.5 GPH AT 5100 RPM as I posted earlier. What TAS did you get in cruise at 5100 RPM?
Rich
