Old 10-25-2006, 01:41 PM
petehowell's Avatar
Default Mag Compass
Hello,
DAR says I need a non-electric compass to augment the electronic one I have that works well. So, I don't want to spend a lot. This looks pretty good. Any experience out there:
http://shop.sailnet.com/product_info...oducts_id/2663
Pete
Amateur Plane - RV-9A N789PH - 1950+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 10-25-2006, 03:16 PM
frankh's Avatar
frankh frankh is offline
Default All I can tell you is
My FAA inspector from the local FSDO did NOT require a mechanical backup to my already battery backed up Dynon.
Frank
7a and a headache
Old 10-25-2006, 03:56 PM
Jerry Carter's Avatar
Jerry Carter Jerry Carter is offline
Default My DAR required a compass
I actually picked one up at Brookstone at the local mall for $15 before my last DAR inspection on my gyroplane. The DAR was fine with that - he said a wet compass just had to be in there for the inspection. He would not let me by with a blue mountain EFIS Lite in my RV-8A, even though it displays heading information. Bottom line, I would put whatever you want in there.
Jerry Carter
RV-8A sold
Old 10-25-2006, 04:00 PM
frankh's Avatar
Default Autoparts store
Have some VERY cheesy looking compasses...well its not like your ever going to use it are you?...Gee it might even accidentally fall out of the plane after the inspection.
Just can't get the quality these days...
Frank
7a
Old 10-26-2006, 06:02 AM
FrankK90989 FrankK90989 is offline
Default DAR VS DAR
The dynon was good enough for my guy.
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 10-26-2006, 06:43 AM
N62XS N62XS is offline
Default Mee Too!
GRT was sufficient on my inspection, even though it is currently suffering inaccuracy from RF interference. I was gonna be way cool and not have any steam guages in my current 8. Lesson learned and I will not repeat that mistake. Get a Vertical Card and panel mount it. In my next 8 and 10, I will definitely have the following:
Vertical Card, Airspeed Indicator, AI(TruTrack), DG and VSI.
All will be 2.25" and located in plain view.
BTW: I will also have two fuel guages as backup.
IHN,
2017 Dues Paid
Robby Knox
"If it is to be, it is up to me" Thomas Smith
Old 10-26-2006, 07:39 AM
JonathanCook's Avatar
JonathanCook JonathanCook is offline
Default GRT backups. 2 1/4 (2.25) instruments
I am planning on a GRT with 2.25" Airspeed, Altimeter, and turn and bank coordinator. I will also have a wet compass. The only problem that I am having is finding a reasonably priced 2 1/4 Altimeter. I am sure that I can get the Airspeed for under $200, the turn coordinator from trutrak for under $500, but a good quality altimeter I can not find in this price range. I plan on flying IFR, so I would like a TSO'd Altimeter. Any help would be great.
Jonathan
Celebration, FL 34747 (just SW of Orlando)
RV7
Working on Fuselage
dues paid for 2012
Old 10-26-2006, 07:43 AM
Default Best I have found?
Check this link:
http://www.wingsandwheels.com/page21.htm
IHN,
2017 Dues Paid
Robby Knox
