Geico266
I would like present a video I made in my RV-12 to show the glide characteristics in an actual engine out situation.
I started out at 6,300' MSL about 5 miles SW of my 1,500'MSL airport. Winds were 120 degrees @ 15 gusts to 23 mph, Runway 17. I weight about 210 and half 1/2 fuel, no baggage, no passenger.
Moderate traffic dictated that I maintained a "normal" pattern rather than a straight in approach for 35 without declairing an actual emergency. Touch down point was the middle of the runway and I came in short around the numbers after slipping hard with full flaps.
My hope in presenting this video is that others may see how much time you have before touch down to look for an airport, road, open field, ect. IMHO it is panic and inattention to airspeed that is your enemy, not the loss of the engine. If you need to panic do it in a bar with a stiff drink a couple hours after landing.
A -12 has a glide ratio of about 13-1 which gives good glide range, and the low stall speed gives good survivability.
Enjoy! About 8 minutes long.
http://youtu.be/_xZmsxEewik
