Old 02-23-2012, 08:24 AM
krw5927 krw5927 is offline
Simply hilarious, Mike! Thanks for the chuckle!!
Kurt W.
RV9A
FLYING!!!
Old 02-23-2012, 12:30 PM
humptybump's Avatar
I'm in trouble! According to Mike's calculations, my plane can't move!
- Glen, ESVA
Old 02-23-2012, 01:42 PM
Mel's Avatar
Mel Mel is offline
Default Unfortunately.....
Originally Posted by mikerkba View Post
These issues, like taping vs. bolting tiedown holes, are readily resolved with info available on VAF regarding relevant critical issues. Its easy.
Formula for speed of your particular aircraft =
(Weight + antenna count) x horsepower x (.1 x minutes spent waxing)
x the square root of weight left in the hangar
divided by factory RECOMMENDED (not placarded) Gross Weight
all times 1.01 for LED lights and, finally, 1.02 for taildragger configuration.
I have disregarded the nominal effects of tire pressure and home field elevation. I will be posting a youtube proof of the calculation.
* assumes you used the correct primer, in the right places, and applied it with a 12" torque wrench using your hand centered on the handle.
This formula is only valid with manual flaps and trim!
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
