I am putting the control sticks in my project. I have Infinity Stick Grips which give me flaps, trim, ident, A/P disconnect, PTT and comm flip/flop. There are a total of 17 wires coming from the stick grips.
Van's has a metal tab that holds a Molex 12 pin connector that allows you to remove the sticks.
With 17 wires and only 12 pins on the Molex I need to find an alternate solution. Has anyone else had this issue, and if so what did you do to rectify it?
Skip the tab and use a bigger Molex seems to be the best option.
Thoughts?
bruce
Thoughts?
bruce
