Saw this on Amazon: https://www.amazon.com/dp/B07JH4XX4...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Looks like it is a perfect paint booth item???
I'm looking at priming more than finish painting. I'm reluctant to setup a full time paint area in the hangar even though there is space for it; fumes and such with some small worry for carryover to other things...... But these canopies would be pretty easy to pop up in the grass behind the hangar for a paint day too. Two walls would block a fair amount of wind
I don't see how a fan (for example a $20 20" Box 3-Speed Fan) can produce sparks, IF if is left on. In other words, put it on an extension cord and switch it on/off at an outlet that is not near fumes. Don't touch the switch on the fan while it's in fumes. These AC fans are brushless, right?
Finn
EC motors are sealed.... found this:https://www.amazon.com/gp/product/B07JMHFJMR/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
Marketed to growers, not builders, eh?
Personally I'm not too worried...
