Old 09-15-2019, 07:23 AM
RV10Man RV10Man is offline
Default 7/16 or 3/8?
I bought a prop from a VAF member for my RV9A. It's the exact prop form Van's for my engine and airplane. BUT, I didn't fully check out my prop flange. My flange is for 3/8" bolts, the prop is 7/16".
My question to the gurus is, can I use this prop and install bushings/spacers, and use 3/8" bolts?
RV9A under construction--N781DM reserved
Donated
Old 09-15-2019, 07:37 AM
Vern's Avatar
Vern Vern is offline
Default Prop flange
The bolts should match your prop for security. New collets for your crankshaft are available. Use a home made removal and installation tool using ordinary sockets, washers, and a same threaded bolt (not one of the expensive prop bolts)
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 09-15-2019, 08:55 AM
cajunwings cajunwings is offline
Default Crank flange drive bushing
Several times I have solved issues like this by replacing the bushings. I usually buy serviceable used bushings from Aircraft Specialties in Tulsa. Bob over there can set you up with what you need.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 09-15-2019, 11:19 AM
chaskuss chaskuss is offline
Default Useful SI
Marshell,
You will find Lycoming Service Instruction 1098P very helpful. See
https://www.lycoming.com/service-instruction-no-1098p
Charlie
Old 09-15-2019, 07:53 PM
Originally Posted by chaskuss View Post
Marshell,
Charlie
Thanks Charlie. I'll check it out.
Donated
Old 09-15-2019, 08:08 PM
merlin3 merlin3 is offline
I'm not saying its right but when I bought i believe it was a prince prop for my old rv i was told it was ok to use bushings.
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 09-16-2019, 03:27 AM
smokyray's Avatar
smokyray smokyray is offline
Default The answer is....
Marshall,
The answer is yes.
Keep the prop like it is and make the spacer match by drilling it out and using 7/16 bolts from Saber or whomever you choose. Bushings on a wood prop won’t work over time and the 7/16 bolts are far superior with an 0-320.
The older 4” spacers like mine on my RV4 had pressed bushings similar to Lycoming flange bushings that were difficult to remove so I drilled mine (and my prop) to 7/16. Reason for me is that 3/8 bolts didn’t hold torque more than 10hrs with my Sterba wood prop in the moist climes of my home state (FL).
You could drill the spacer yourself or send it to Saber mfg and have Sam drill it for you or just buy a new spacer from Saber.
V/R
Smokey
Old 09-22-2019, 06:54 AM
Originally Posted by smokyray View Post
Marshall,
The answer is yes.
Keep the prop like it is and make the spacer match by drilling it out and using 7/16 bolts from Saber or whomever you choose. Bushings on a wood prop wonít work over time and the 7/16 bolts are far superior with an 0-320.
The older 4Ē spacers like mine on my RV4 had pressed bushings similar to Lycoming flange bushings that were difficult to remove so I drilled mine (and my prop) to 7/16. Reason for me is that 3/8 bolts didnít hold torque more than 10hrs with my Sterba wood prop in the moist climes of my home state (FL).
V/R
Smokey
Thanks Smokey.
Problem is, it's the other way around. The prop, spacer, and bolts are 7/16, my crankshaft (prop) flange is 3/8.
Donated
Old 09-25-2019, 07:36 PM
PropMan PropMan is offline
Give Sam at http://www.sabermfg.com/ a call. buy a set of drive lugs for the 7/16" bolts(preferred over the 3/8 anyhow). press out old lugs, press in new ones. Situation all good.
Frank
RV6-N164FJ sold sadly
Legal Eagle w/Verner 3VW
Rans S7s
RV4- in progress
Old 09-25-2019, 07:46 PM
Thanks. I'll give him a call. Granbury isn't that far away from me anyway.
Donated
