DennisRhodes
Has anyone found a good way to install rivinuts DIY ie 6-32, 8-32 and or 10-32 without the driver tool? . I often would like to install one or two but have never had the need for purchasing the driver tool. Most of the automotive tools use the Metric size nuts and I don t want to start that. I ve seen the video where you use a battery driver and coupling nut but not much luck with rotating the screw for installing them, it usually pull the threads out of the nut.
