Old 01-18-2019, 08:00 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Time
Originally Posted by Walt View Post
I plan on around 3-4 hours if no major problems are encountered.
Only a little off topic - I asked because I was considering a cross country out to see you to get said check and a prop balance. Trying to figure out the timing and logistics. About 4 hrs one way from North Alabama.
Dan Langhout
2019 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
530 hours and counting . . . .
Now based at Moontown (3M5)
Old 01-18-2019, 09:08 AM
Walt's Avatar
Walt Walt is online now
Originally Posted by Scott Hersha View Post
$400 here at KHAO - Cincinnati area. It takes about an hour for G3X touch, G5, GTX45R with no issues, a little longer it there are leaks or other problems, but the price will usually not change.
Wow, it takes me at least 30 min to get set up and then a 20-30 min warmup period (that's after you get external power hooked up) before I even get started.
Guess I'm just getting really slow in my old age
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs, New Titan IO-370, Bendix Mags
Old 01-18-2019, 10:45 AM
Slow? Or cautious after having learned from much experience?
Thanks, I'll take the "do it slow, do it right" route!
Old 01-18-2019, 12:39 PM
GaryK's Avatar
GaryK GaryK is offline
I just had the IFR done on the 10 and transponder check on the Highlander. A little over an hour for both. The majority of time was on the 10 (dual AHARS and G5). The same guy did it 2 years ago so knew the routine on the Dynon equipment. He said the biggest issue is chasing down leaks in the system. I did not have any so it was pretty quick.
Gary
