I will be installing an archer VOR antenna in the wingtip and coax will run in a conduit with other wiring. One wing has a servo that will generate PWM output for RAC servo trim. The ohter wing will have Pitot Heat wiring that will draw 10 amps, when on.
My question for the expers: Which environment is less harsh for the nav signal running down the coax?
