The one I have is from Cleaveland Tools.
Essentially one line hooks up to your normal air source, the other to your squeezer. Then you take a rubberband to hold the trigger on your squeezer closed.
It works really slick for pieces that you can rivet while sitting down (the first part of assemblies and such). I've also clamped the squeezer down to the table, facing "up" so I could have both hands on the piece. This is great for dimpling structure (ribs and other parts it's tough to get the DRDT2 into) as usually I can hold the piece with both hands and move it around.
But once the piece gets large enough you end up being on your feet moving around.
Make sure that you can feather this pedal like you would the trigger. If this amazon one (a bit inexpensive compared to the cleaveland one) doesn't let you feather you'll get into trouble.
