I fly an RV-7 with the IO-360 w/ slick mags it has about 400 hrs on it. Recently, I've had trouble with hot starts. I use the full throttle mixture cut-off dance; which up until this summer has worked without fail relatively quickly. Lately it's been much more difficult to start hot, or even warm after it sits for an hour or so. Every time except once I was able to get it started eventually but took a fair amount of cranking which is not normal (and to be honest slightly embarrassing when you're at a fly-in with people watching ). Cold starts are no issue and it usually fires after 3-5 blades. No other anomalies once started.
I guess my question is where to start looking, it feels like ignition but I'm not sure. Spark plugs looked fine in May, mags haven't been touched. second option is I'm just out of practice with the dance and its pilot error, but it doesn't feel like I've changed anything.
