Well I was ready to rivet the skin to my canopy frame today to get ready to glue the canopy to it next week. I had noticed the fit on the right side had changed a little, but I thought it had to do with the 3 strengthening pieces between the frame and skin. I put the blank panel in for the first time with the canopy frame installed and there was a huge gap near the middle on the right. I discovered the tube on the frame had cracked. Talk about a punch in the groin!! I have an email in to Vans to see if it's something that could be welded or if I have to replace it and start over. UGH!! This was also the first time I realized that that tube and the huge gap between it and the skin on the outer edges are visible from inside the plane. Now I know why guys use fillers to fill in that gap to make it look nicer. For some reason I thought that tube was behind the panel when the canopy closed.
[/IMG]
