Hi,
what are you running your Lycomings on?
As far as I understand the Lycoming writing, lead is not needed. However, they strongly advise not to use pump gas.
Now, in Sweden we do not have Mogas (but we have UL 91/96). When Lycoming is writing Mogas, what does it actually mean? Is it any alcohol in it?
Do you run your Lycomings on fuel also containing alcohol? Any problems with damage rubber?
Do you also run on pump gas? Any problems?
Here I have the choice of running on 100LL, UL91/96 or Pump gas. I will not tell you what we pay for 100LL, you would not believe it anyway. If Lycoming engines runs fine on pump gas with 5% ethanol, it would save me alot.
