After mounting the engine and mount to the firewall, I temp installed the cowling to the airframe and noticed there is about 1/2" from the front of the ring gear to the front edge of the cowling.
I noticed my cowling has the "CS" marked on it and i'm using a wood prop.
Is it normal to have to trim the back of the cowling to get the fit needed for the prop/spinner?
I was under the impression that most 6's needed a prop spacer of some kind.
