tomkk
We're assembling the nose wheel as indicated in 35-08, Fig. 1. The length of U-01210A-1 is such that when the nut is fully tightened there is barely any compression of the wave washers and there is no bearing drag at all when the wheel is turned.
I'm used to tightening the axle nut so that slight drag is produced from the bearings and then backed off slightly. U-01210A-1 is long enough to preclude getting any drag on bearings at all and virtually no compression on the wave washers. Can that be right?
