Simon Hitchen
Hi guys,
I’m running a Titan IO-360 with an Avstar FI unit monitored by a dynon skyview. In the cruise I lean the engine to LOP and then continue to lean until the first cylinder to peak (#4) reaches 50 LOP. The engine runs beautifully at around 7- 7.5GPH but this leaves the last cylinder to peak at around 20 LOP I think i May be doing this wrong...should I be continuing to lean until the last cylinder to peak is running 25-50 LOP? This would leave the first to peak at around -80 LOP.
Many thanks
Simon
Many thanks
Simon
