I am having a 51' wide by 64' deep by 12' high hangar built.
The front 40' will be hangar and the back 24' will be an enclosed shop.
The electrician is proposing using Eaton LED lights.
1.) Regarding the shop area, if the CRI greater than 80, what is an appropriate temperature? Namely, with the CRI greater than 80 should the temperature be greater than 3500 K?
2.) For the shop area, is 50 FC a minimum or recommendation? My goal is that the shop area should be lighted like one would for a work bench. So, since this new construction, it would better to cover the need now rather than add later.
3.) The proposed lights are the Eaton Metalux Value High Bay Linear LED VHBLED-LD1 lights. Any concern that in the shop that they will only be at an a 10 1/2 foot height due needing to be 1 1/2 from the ceiling and at 12 foot height in the hangar (i.e. mounted between the rafters)?
Thanks.
Brett H
Columbus, IN
RV-12 Finishing Kit
Thanks.
Brett H
Columbus, IN
RV-12 Finishing Kit
