Old 01-03-2018, 10:37 AM
rvman008 rvman008 is offline
Default Electric and Manual trim
Does anyone have both electric and manual trim? I would prefer to have both in my aircraft. I once accidentally kicked my trim hat on my stick while getting out of my aircraft. I later flew the aircraft and found out the trim didn't work. I had to fly back to my home airport around 80 KIAS to minimize stick forces. Anyone have an ideas on installing Manual and Electric Trim?
Old 01-03-2018, 10:59 AM
6 Gun 6 Gun is offline
Default trim
Take the wires off switch and take a 9v battery and set trim were you want it.
Old 01-03-2018, 11:45 AM
Sam Buchanan's Avatar
been here awhile
Just run manual and be done with it!
This one probably needs to go in the "Never Ending Debates" forum...
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 01-03-2018, 12:29 PM
pvalovich pvalovich is offline
Default Trim
After experiencing manual trim in a Cessna 172 and a friend's RV, I don't see why any reason for it. Electrical trim is much easier, and except for nose up trim in the landing configuration, not an override problem at any normal setting.
I did include both roll and pitch trim cutoff switches during the build, but now wish I hadn't.
FWIW - I also think the operational advantages of electric flaps far outweigh any reliability concerns leading to a manual flaps decision.
Old 01-03-2018, 12:59 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is online now
No, canít do both with standard RV trim.
RV-8 (steam gauges), RV-9A at KSAV (Savannah, GA; dual screen G3X with autopilot, GTN 650)
Previously RV-4, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2018 dues paid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 01-04-2018, 08:00 AM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default An idea
If you are looking for ideas, how about the ability to manually move the trim servo? I recall that the servo in the elevator is a pretty tight fit but you might be able to get about 1/2 inch of travel.
John Morgensen
RV-9A N946PM 500+ hours since 2013
Nevada/Arizona
