Old 01-01-2018, 02:46 PM
donaziza's Avatar
donaziza donaziza is offline
Question Avionics sitting in cold weather??
Anyone know if long periods of sitting in cold weather is harmful to avionics? Nothing exotic, just a Garmin 496 and a Dynon 180. Obviously, the 496, I can take home, the Dynon, no. Also got a Nexus 9 Android which I always take home, as Garmin Pilot is always putting out updates.
Just wondering.
Old 01-01-2018, 06:26 PM
If it's cold enough, your Li ion back up batteries may stop working. But it doesn't get that cold in Atlanta.
Old 01-01-2018, 06:33 PM
DNeufeld DNeufeld is offline
Leave a 60w trouble light on in the closed cockpit.
Old 01-01-2018, 06:36 PM
Mel's Avatar
Mel Mel is offline
Be very careful doing this. Make sure that the bulb cannot touch anything flammable like upholstery or carpet.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 01-01-2018, 06:41 PM
pa38112 pa38112 is offline
It does not hurt for them to sit in the cold, but if you try to use them in the cold it can cause the display to cut out. Most avionics that are temperature sensitive have an internal heater, but I try to get them up to 50 degrees before turning them on.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 01-01-2018, 08:13 PM
Rallylancer122 Rallylancer122 is offline
I heard that on some of the older Apollo/Garmin GPS's the LCD's could freeze. My Dad left one in an unheated hanger for a few years (Wisconsin) and when I put power to it last year it powered up but the screen was kaput. These were late 90's era, and I'm told more modern stuff is ok.
That being said it always seems like the mechanical gyros make more noise starting up when it's really cold out. If it's that hard on the bearings in our engines (which we religiously preheat), how is it better for them? I've resorted to throwing a space heater in the cockpit as part of preflight.
I would never leave any heat generating source in the cockpit unattended.
DEM
Old 01-01-2018, 10:12 PM
donaziza's Avatar
Originally Posted by RV8JD View Post
I see you're in Atlanta ... cold, huh? (Just kidding, just kidding!)
Anyway, check out pages 11-8 and 11-11 from the D180 Pilot's User Guide:
"Operating Temperature: -22 to 122 F (-30 to 50 C)"
Yeah, but I grew up in Milwaukee---and one doesn't forget 15 below----even if the airplane is not technically there.
Old 01-02-2018, 07:00 AM
Skid's Avatar
Skid Skid is offline
I wish I could forget. Its -12*F this morning here off the west end of Lake Geneva this morning, a bit warmer in Milwaukee.
However the airplane is in a 55* F hanger
Skid
RV-6A
IO-360 B1B
Old 01-02-2018, 06:35 PM
Super Moderator
Be very careful when moving them out of a heated hangar into really cold air. I had a canopy crack on me one morning due to the very rapid temp change. Probably my fault in closing it too hard. Just move things very slowly and carefully.
Vic
Vic Syracuse
Kitplanes "Checkpoints" monthly column
www.Baselegaviation.com
Old 01-02-2018, 07:34 PM
Skid's Avatar
Thanks Vic, but its in for the winter. The runway is grass and does not get plowed so no flying until we get a thaw.
I had a similar problem a few years back. I left the canopy closed on the ramp to keep the heat in the airplane on a 20* day during a trip to Lima OH. I then launched and climbed like an express elevator to 4500, about 10 min later the canopy cracked with a bang.
Scared the you know what out of me.
Skid
RV-6A
IO-360 B1B
