Old 12-24-2017, 06:56 AM
Jesse's Avatar
Jesse Jesse is online now
Default GSA28 pitch Servo wonít auto trim with VP-X
I am working on my second install of a G3X system with a VP-X and I get a short circuit on my pitch trim when it runs through the auto pilot Servo. The trim from the Servo works, but not the trim from the VP-X. Anybody else have this problem?
Jesse Saint (Saint Aviation, Inc. - VAF Advertiser)
352-427-0285
jesse@saintaviation.com
RV Hotel (hangar, room, car) at X35 in north FL
Commercial ASEL/S A&P/IA EAA Technical Counselor
Dynamic Prop Balancing, Prebuy Inspections, Condition Inspections, Repairs and Mods, Injector Tuning, Airframe, Engine, Panel Upgrades, Ferrying, etc.
Old 12-24-2017, 02:20 PM
Jeff A's Avatar
Jeff A Jeff A is online now
Default Bypass the servo.
Disconnect the connector from the servo (GSA28 autopilot servo, not the trim servo) and jumper pins 11&13 and 12&14. If the trim servo operates normally, you’ve got a bad Garmin autopilot servo.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 12-26-2017, 05:40 PM
Jesse's Avatar
I did that on both installations with the same result. The roll auto trim works fine on both. Iím just wondering if there is something between the VP-X and the G3X that is a known issue.
352-427-0285
Old 12-26-2017, 06:07 PM
Brantel's Avatar
Brantel Brantel is offline
My VPX works great with the Garmin Servos and trim servo.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-02-2018, 08:51 AM
Jeff A's Avatar
Jesse,
Not sure if you ever had any success with the servos, but this is how my autopilot servos and trim servos are wired to my legacy (not Sport or Pro) VP-X and they all function perfectly.
Jeff Atkinson
