Old 12-19-2017, 07:16 PM
Originally Posted by cdeerinck View Post
The easiest solution is to just keep your required documents in a zip-loc bag, and keep that in a pocket in the plane. It protects them and leaves them easily accessible for inspection. Airworthiness, registration, and any not often used cheat sheets for avionics are in mine.
Well, strictly speaking, I think the A/W certificate is supposed to be visible.
Old 12-19-2017, 07:40 PM
Correct
That one document must be viewable at the entrance of the aircraft. The rest can be tucked away somewhere safe.
Scott McDaniels
Hubbard, Oregon
Old 12-19-2017, 07:43 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Originally Posted by Mel View Post
Yep! Just follow you operating limitations. You must place the aircraft back into phase I for testing if the replacement is not the same make and model as the one removed.
And submit a new 8130-6 to FAA if changing of a fixed pitch from or to a controllable propeller.
8130-6.... would that apply to going from a Ground adjustable whirlwind to a Catto?
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 12-20-2017, 05:28 AM
DanH's Avatar
DanH DanH is offline
Wee detail (of which I'm sure Mel is aware); Many of the older operating limitations out there (like those issued in the 90's for example) included a requirement to inform the FAA and receive a response prior to resuming flight after a "major change". Most assumed it meant a letter to your local FSDO (and a wait for a written response), but there was confusion/variation all around. The provision was removed from later wording, but if it is in yours, well, as Mel said....just follow your operating limitations.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-20-2017, 06:36 AM
Mel's Avatar
Mel Mel is offline
Default Exactly....
As Dan says, op lims have changed over time. Regardless of when yours were issued, they are the controlling document. If you prefer a later version, then you must have yours amended. Until that time, you are bound to the op lims issued to your aircraft.
Is that confusing enough?
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-20-2017, 06:54 AM
Timberwolf Timberwolf is offline
My original ops limits didnít provide the ability to fly IFR. Called up the FSDO, sent in the paperwork and had new docs in 2 weeks. Painless process for anyone else interested in updating theirs.
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P in progress
Aero Engineer, A&P
Old 12-20-2017, 08:07 AM
Mel's Avatar
Mel Mel is offline
No! Ground adjustable and fixed pitch are regarded as the same in this instance.
Only when changing to or from an in-flight controllable propeller do you need to submit a new 8130-6.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
