Old 10-30-2017, 01:14 AM
SteveT SteveT is offline
Default Wordpress blog - tracking build hours
Iím using Wordpress blogging software for my build log. Has anyone found a great way to track the hrs spent building other than having to manually add up hrs youíve entered into blog posts?
Iím thinking a custom field can be used - but before I go digging, I wanted to see how others may be doing this.
Steve Thompson
Scottsdale, Arizona
RV-14 #140437 - building the empennage
N45KK reserved
http://www.airplanebuild.com
Old 10-30-2017, 01:34 AM
rv8ch rv8ch is offline
Default Do you really want to know?
I've used two different blogging packages for my build, and neither tracked hours. I'm on wordpress now, and it's ok. I usually make a note in a paper notebook about my time in the shop, but I forget to from time to time. My question is, do you really want to know how many hours you spent in the airplane factory? I have not added mine up, and I don't plan to!
Mickey Coggins
http://rv8.ch
Old 10-30-2017, 08:45 AM
DaleB's Avatar
DaleB DaleB is offline
I was doing just that. I had a custom field named Hours, and used PHP to total it up for display in a widget, as I recall. It worked pretty well.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 10-30-2017, 09:20 AM
Glad to hear that helped you. I did see a facility for a custom field in Wordpress but haven't researched it yet.
Steve Thompson
Scottsdale, Arizona
N45KK reserved
Old 10-30-2017, 09:25 AM
Default Hobbs meter
Best idea on this site was to use a old Hobbs meter on a light switch.
John S
Dues paid 2019, worth every penny
Fuselage 30%
DaleB's Avatar
Fairly easy to use. I used a PHP widget for the totals. For some reason that stopped working, but I sold the project shortly before it did so I never bothered to investigate. I'm building again, but not tracking hours this time.
Dale
Omaha, NE
Old 10-30-2017, 09:49 AM
N546RV's Avatar
N546RV N546RV is offline
I use a custom field, and way back when I did this I found someone who had put together a plugin for hour tallying, but it didn't quite work right, so I ended up having to hack it a bit. I think it worked OK for overall hour logging, but I wanted to also have hour totals per build phase (tail/wings/fuse/etc), and I believe that was the part I had to muck with a bit.
End result can be seen in the sidebar here: http://rv.squawk1200.net/
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
