Old 09-11-2017, 11:10 AM
RicoB RicoB is offline
Default Avionics Cooling fan
What have you guys done about that? I am at that point so trying to get ideas. I love to use the cyclone 21-3 but the price is pretty steep for a fan!
Got ideas and pics to share?
Rico Burgos
RV9a - Building with a partner (avionics 99% done, Baffling in progress.) Planning to have it flying by the end 2017
Based at KWHP (CA)
C-150 Based at KMOD (CA)
Old 09-11-2017, 11:20 AM
Raymo's Avatar
Raymo Raymo is offline
I have a few cooling fans out of old HP servers that work great. They run on 12 volts, are light and inexpensive. Mine comes on with the nav lights.
I have several extras if you'll donate $5 to VAF and pay shipping (USPS small box or padded envelope).
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Auburntsts's Avatar
I didn't install one. My GTN 650 has a built-in fan, but I don't think that in most instances an external fan is required for today's avionics. However, I have nothing factual to back that assertion up.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 09-11-2017, 11:48 AM
rleffler's Avatar
rleffler rleffler is offline
My Garmin transponder was the other thing in my panel that needed a dedicated fan port. I added two standard computer fans on the glareshield. They solve two issues. The first is to remove hot air trapped behind the panel. The second is function a defroster when the temps start to drop.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 09-11-2017, 03:07 PM
SteinAir SteinAir is offline
Many of the modern avionics and EFISes have their own cooling fans in or on them, and in addition to that perhaps the most important thing is to have some sort of vent holes in the glareshield (or even a couple muffin fans). That should allow that dead space between the main panel and sub panel to be ventilated and kept at a good temperature, so everything should be good (as Bob noted, those glareshield fans also work as defrosters too).
Just my 2 cents as usual!
Stein
Old 09-12-2017, 12:53 AM
I guess I forgot to mention that mine is a tip up canopy so fan placement on the glare shield is not quite the same!!
Rico Burgos
Based at KWHP (CA)
Old 09-12-2017, 03:17 AM
Wingnut Wingnut is offline
Default I believe it
was Bruce Swayze that did an excellent job of describing how to mount fans in his tip up glare shield. Check his build log website for details. 09-30-15 entry.
Con Kelley
RV7
Empennage and wings need tips
Fuselage kit "finished" (for the moment)
Finish kit and FWF in progress
Hartzell CS
Aerosport Power IO-360, Dual Pmags, AFP FM200 FI
C-150 at 7FL4 (sold)
www.mykitlog.com/cakelley
www.1379.eaachapter.org
Old 09-12-2017, 06:35 AM
bobnoffs bobnoffs is offline
i made a heater with an oil cooler core and these fans.
search ''pancake fans'' on ebay and there are dozens.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying
RV-12 kit as of 9/13
Old 09-12-2017, 06:53 AM
Auburntsts's Avatar
Stein
I should have stated that I also have 2 glaresheld vents too.
Todd Stovall
PP ASEL-IA
WAR EAGLE!
Old 09-12-2017, 09:38 AM
flion's Avatar
flion flion is offline
When Stein speaks avionics, we should all listen.
My -6A has a fan but no venting in the glare shield and pooled heat can get to around 150 degrees on a hot day. The -10 will have vents and has two fans to service the ports on the G900X components and the LSE ignition boxes. Those fans are mounted on the sub-panel between the G900X racks and are updraft to draw from cooler air below the panel and any air not forced into the cooling hoses will be sent up toward the glare shield vents. Don't count on your avionics having fans and, even if they do, you still want to be sure air moves from under your panel so you're not 'cooling' your avionics with hot air.
And, while the -6A panel is out this winter getting updated, I will rectify the dead air situation behind the panel.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
