Old 11-06-2016, 07:49 PM
wirejock's Avatar
wirejock wirejock is offline
Default Right angle attachment
Do you have one of these?
I use it to drill in close quarters. First with #40. Center punch is your friend.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-06-2016, 07:59 PM
amaris amaris is offline
Hi Larry,
Yes, pretty similar.
http://www.cleavelandtool.com/90-DEG.../#.WB_sqNyELA8
The diameter of the angle hits against the rib so it forces the bit at an angle. I tried the long bit and the shorty bit but neither gets in there.
Allen Maris - 2018 Dues paid
Santa Ynez, CA
Old 11-06-2016, 08:28 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Originally Posted by amaris View Post
I'm starting SB-14 and just need to drill out the 8 rivets on the flange connecting to the spar. I can't get a drill in there and the angle drill still hits the rib which won't allow me to drill straight down into the rivet.
Thanks for the help!
I use a 12" 1/16" bit to pilot drill the head, then move up in sizes. You can flex the bit with your fingers (although I made a brass guide) enough to clear the drill motor and chuck.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 11-07-2016, 10:35 AM
Thanks, Mike!
Santa Ynez, CA
Old 04-02-2017, 08:56 PM
TomRV8 TomRV8 is offline
Default Rivet remover 'tool'
This works well with rivets needing to be removed close to an edge. I had the swivel head on one of my 1" clamps disappear. I rarely throw anything away, and finally came up with a good use for the dismembered clamp.
I sharpened the end of the screw in shaft. As the pics below show, I used a 1/4" drive 3/16" socket as the backing and receptacle for the shop end of the rivet to be drilled out.
Use the good advice in this thread to drill and remove the manufactured head of the rivet to be removed.
Then simply place the socket over the shop head of the rivet and screw the clamp shaft into the rivet. Works quite easily.
I used it for a while with the socket loose, and manually lined it up with the clamp. I finally broke down and used JB Weld to permanently attach the socket (which I cut shorter for a little more room between the jaws of the clamp)
I also recently discovered that when drilling the manufactured head off the rivet, and part of the head pry's up but not quite all of it, instead of drilling more, I place the tool over it and when screwing down it pops the manufactured head off at the same time as poking the shop head into the socket.
Tom Chapman
San Antonio, TX
Building RV-7A Tip Up IO 360 A1B6
Flying RV-4 since 1988
Flying Rans S-7S Courier
RV-8 build on hold
Old 04-09-2017, 12:43 PM
smithflys23 smithflys23 is offline
Does anyone have a source for the original posters drill bits? I cant find a Jobber bit in 3/32, or #40 with the 60 degree point. Any help is appreciated!
Old 04-09-2017, 04:32 PM
BillL BillL is offline
Actually, the OP just used standard drill bits.
The second post, however: You might give Cleaveland a call, that looks like a plexiglass bit.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
33/40 hrs
Aerobatics DONE!!
2017 Dues Paid
Old 04-09-2017, 05:08 PM
Sorry. My mistake. Thank you for the tip. I will give Cleveland a call.
Old 09-04-2017, 08:08 PM
vernon smith's Avatar
vernon smith vernon smith is offline
I had the occasion today to try to drill out a 470 and soon found keeping a drill (135 degree) centered to be nearly impossible. I made up a simple drill jig that centers the drill on the rounded head and sends the drill dead down the middle of the rivet. It can also act as a drill stop so you don't drill clear through. If you use it for a stop you will have to clear the chips from the guide tool several times.
Of course, a different drill jig will be needed for each rivet diameter. I did mine in a lathe because I have one, it can be done in a drill press by a very good eye for the center of the fixture. I do not recommend trying to make one with a hand drill and a vise.
I cannot be the first person to make one of these
Old 09-05-2017, 07:50 AM
JonJay's Avatar
JonJay JonJay is offline
Here is a commercially available tool. You can set the drill depth and chips clear automatically. I have used this to remove hundreds of 470's. Works on all sizes.
http://www.cleavelandtool.com/Rivet-.../#.Wa6qQdRHarU
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
