I did a search on engine starter stalling, and came up with nothing. I must be the only guy with this condition. I keep a battery maintainer, designed for the Odyssey battery, on when not in use, but when I use the starter, it will stall at least a time, or two, before I get a spin up. Starting is always good, once I get a spin. It is important to note that this condition has been there since day one, and I now have 110 hrs. on it. I am beginning to wonder if I may have a weak battery? Today, I did a check. Without the battery maintainer hooked up, I checked the voltage after a few minutes of settling, and it was a 13.2 volts. With my meter still attached, I brought up the Skyview, and the voltage dropped to about 12.7. I then turned on the master, with all of the radios, auto pilot, and fuel pump on, and the voltage settled at 12.25. Then, when I shut everything down, the voltage came back, settling at about 12.8. That doesn't sound too bad to me, but I sure am no expert. I am considering adding an extra ground strap, directly from the starter to the battery, to see if it would help. Any thought will be greatly appreciated............Tom
