sbalmos
Hi all,
Posting as a new thread here so that I don't pollute the original EFII thread. Attached, by popular request, is my pencil-to-Visio conversion of my designed primary power bus. This was written up at Oshkosh with input from Chad. I'll open it up now to the forum at large for comments, possible improvements, etc. Hopefully it doesn't diverge to a flame-out.
http://sbalmos.fastmail.fm/Primary%20Power%20Bus.pdf
Some notes of what I did/found:
Thanks for any considerations all.
- Because the Bus Manager's Essential Bus is running everything ignition and primary avionics, Chad and I agreed there was no reason to go VPX Pro
- I am adding a "Fuel Pump Master" switch, so that one can have on the essential avionics and also the ECUs for programming, without having the rest of the ignition system "hot"
- The push-button starter I am still hanging off of the VPX, to make use of the starter enable ability. This still wires to the starter switch pins in the Bus Manager. This may be a point of contention, but I don't mind re-enabling the Main Bus to start
- I leave the GTN 650 as an essential piece of avionics because selfishly I want it to be COM 1, which is the only thing cut-through in the audio panel if power is killed to the audio panel. And also I can do a full instrument approach by hand if necessary in an essential power situation.
- Obviously not every detail is shown, but this is the master main layout I'm going off of
