Section 25-02 - bulkhead bars
Chris Cooper
Active Member
You have to double flush rivet the Bulkhead Bars together but nowhere does it say to countersink them? Have I missed something? I have read it 20 times now....
Thanks, I?m assuming they have to be countersunk to allow them to be flush riveted though. Seems like a stupid question but I?m paranoid of an expensive mistake...
The farther you get in the plans, the more little details are left out--------this is an educational process and the need for step-by-step "hand holding" is not as great as when you first start.
Don?t forget section 5
Chris,
Vans frequently instructs you to do a procedure that is explained in section 5. I have had to remind myself that if they tell me something in section 5 they often expect not to have to repeat themselves later on.
In this case, double flush riveting is discussed at length in section 5.8 including the countersink process.
