Kahuna
Moderatoring
If the GDL is remote mounted (not a sky view), external ADSB antenna, and its bluetoothed to a 796, does the 796 pass GPS position to the GDL39 over the bluetooth?
Trying to figure out if I need the remote antenna or not dedicated to the GDL 39. Seems silly to have to need that if its talking to a gps through 796. I can see the need for the GPS data if it were not talking to a gps, in the case perhaps of just talking to an iPad passing weather as an example.
I was acutally going to hard wire the GDL39 to the 796 BUT the only serial port you can do that on is 1, and Serial 1 is the only one with the serial in/out functions I need to interface to other devices with the 796. The pass through serial on the GDL39 is not an option as that data stream type 796 to GDL39 is not what other devices will use for protocols for flight plans etc.
Thanks for your help.
