I am curious about the overall strength of the RV6 verses the 7. I have had several builders tell me the 6 is actually a stronger wing. This seems to go against Vans specs and gross weight for each aircraft as well as VNE. It may be the 7 has a higher weight then the 6 because of the additional wingspan however I understand that the wing attach method is very different between the two aircraft. Any comments or thoughts?
George
George
