Yes. Van's makes an oversize instrument panel. Installed in my 6A, the slider version is F-6103 OVSZ and costs $72.20. This instrument panel blank adds an additional 2.2" of space compared to the stock version.Does Van's (or anyone else) make an oversized instrument panel for the -7A slider? I'd like an extra inch in height.
p.s. Your labelling looks good, Brian. Is that another example of Decal Pro labelling?
To get around that potential headache, I fabbed a small extention to contain the cable assemblies. Attached with 3 screws/nutplates at the flange it can be quicky dropped clear and away from the main (oversize) instrument panel.You can also put your control cables in the panel but if you ever want to pull the panel, you have to disconnect them from the engine......
