flickroll
I have a Bob Archer antenna in my wingtip but am not satisfied with it's performance. The antenna is OK, however with HID lights in close proximity to the antenna the sensitivity of my SL30 Nav receiver is reduced significantly.
I am thinking about installing a RAMI AV-12L cat whisker antenna on the underside of my -8, close to the tailwheel, just aft of the F-810-B bulkhead. Does anyone have any data about the drag that will be induced by this antenna? I suspect it will be negligible, especially considering where I will mount it which will be in significant turbulence from the prop and the exhaust. But if anyone has before and after numbers with this antenna or the Comant equivalent I'd appreciate any insight.
