Just about everyone at our field uses this one ...
https://www.amazon.com/gp/product/B076S6KBP2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Would you hear the alarm buzzer on this unit if you were wearing an active noise reduction headset. You may or may not see the alarm light depending on where it is mounted. Generally RV pilots don?t tend to have too much panel real estate ahead of them.
Would you happen to know if the Aithre will connect with ANY of the Advanced Flight System EFIS, or just the newer ones..? My AFS is a little older (3400 series, one standard screen and one synthetic vision screen)....just wondered if the older software supports this...thanks in advance.
I've got this one as well in my RV8. I tested to make sure it works with candles, car exhaust, and it trigged once that I can recall when I was waiting to line up with wind at my back. It seems to work well. Normally it shows 0, which is what I want. I power it on for the calibration step after moving the aircraft out of the hanger with the canopy open and of course engine off.Just about everyone at our field uses this one ...
