AX-O
All,
I have been doing research on the McCauley hubs. Lots of info here but seems to be potentially obsolete based on the dates of the threads, people gave up on trying the combo on RVs or folks figured it out. I also found info on the McCauley website.
I am working with Catto propellers to develop/test a constant speed prop for RVs.
I cannot find any engineering drawings showing dimensions between the prop mounting flange, spinner back-plate mounting flange and/or the differences in dimensions between hubs. All I can find in their 500-plus-page doc is 4.5 or 6.5 inches from prop flange to center of the blade. I did call McCauley but long story short, no help.
Does anyone know where I can find that info? I was thinking of using the maybe the C211 or C214 hub, or the C220 hub since I have a 4-inch extension on my plane.
Thanks for any info that you can provide and for minimizing the thread drift.
Craig has been running the first constant speed prop on the test engine/stand for several weeks now. Hope to be flying the RV version in Jan if I can figure this stuff out (fingers crossed).
