I really like the idea of painting before first flight and since I have not found a suitable painter, I have decided to tackle it myself. I hope I don?t end up regretting this decision.
So far, I have done much of the fiberglass work to a near paint ready stage, this is all except the cowl.
My choice of paint is a car type paint (base/clear) and I believe either Valspar or PPG would be the MFG but I like to get more info and recommendation on the MFG.
So far, the process in my head is to
- Wash clean and sand (150-180 Grid) the bare aluminum/fiberglass parts
- Take care of any of the imperfection, rivet gun smiles, with Evercoat Metal glaze and sand to feather edge
- Clean the area to be painted with acetone thoroughly
- Prime with Transtar 2K DTM primer then sand with 600 grid to get all the minor defects
- Primer- Seal with the same primer, Transtar 2K but different mixture
- Paint with base coat within the specified time (about a day) after sealer has been applied.
- Apply clear coat within the specified time after base coat
Questions:
Any other prep work on the bare metal is needed?
How important is to do the sealer if the primer is smooth and ready. Will just sanding be sufficient for adequate adhesion and bonding?
Questions:
