Thunderpig
Member
Morning all...started with Section 9 yesterday and am now mired in trying to mate up E-903, -904, -913. First one cleco'd together just fine, lays nice and flat. Second one, I am having significant issues with. Individually, the pieces are laying flat with very little wobble. I cleco'd in the center, longer piece in then have been trying to use the smaller rib to determine where the items are misaligned. When the center, longer rib is installed, it lays nice and flat with no wobble...then when I put the smaller rib in..this is what I see...
http://u.cubeupload.com/Thunderpig/IMG0186.jpg
http://u.cubeupload.com/Thunderpig/IMG0187.jpg
http://u.cubeupload.com/Thunderpig/IMG0188.jpg
One side has the rib flange well above the E-913 piece, the other side settles in more and from the bottom you can see that when the flange holes are cleco'd to the -913, there is a significant gap between the pieces. I'm pretty good at spatial orientation, but this is not making any sense. I measured the smaller flanges, there is about a 1/32" difference in height at the end pictured.
