I bought a 22 cu ft system from Aerox at OSH after reading all the various posts on the pros and cons of MH pulse demand, SkyOx one setting valve, etc. Couldn't justify the added expense at this point. I plan on using two of the Aerox mounting brackets to mount the bottle to the right side baggage compartment. I saw a picture of a bottle mounted there but had questions about the installation. If you have a similar installation, I'd appreciate pictures and details. Did you put in a doubler to support the clamps where they attach? Feel you needed to reinforce the floor (tank weighs 12 pounds full)? Use nutplates instead of the supplied bolts and nuts? Any advice and pictures would be appreciated. Thanks
