This sounds strange to me.
I have 4 identical sets of Crow harnesses in my plane. They all fit fine. They were all ordered as 5 point harnesses, and I just didn't install the anti-sub belt.
No idea about the ones that you order from Van's though...
Vans no longer sells the 4 point rear seat belts for the 10, only 5 point. I've already removed the 5th attach point and already have the vans front belts. Anyone know the source vans was using for their belts so I can match what I already have in the front?
Where the front belts attach to the cabin top, there's a curve to the connecting bracket which doesn't exist for the rear seat belts.
Is that the only difference with The Vans belts? I thought there was a length difference between front and rear?
Found out from Vans the one man shop that supplied their belts is no longer so they are referring people to other vendors.
Long story short I'm ordering rear Crow harnesses and eventually will replace fronts to match.
I've got Crow harnesses. As Todd says the lengths are different between front and back, but the rear belts also come together and have a single attach point at the anchor - same as the front belts.
Joe, the stock harnesses all have a single attach point but the fronts merge into a single strap before the anchor while the rears don't.
I understand. With the Crow harnesses both front and back merge into a single strap before the anchor. Here's a link to their web site showing what the 5 point rear straps look like.
http://www.parts123.com/parts123/dyndetail.pta?catalog=0000371a&ukey=AAAMI
