Folks hoping for some guidance here. I've read section 5.13 of the construction manual a few times and also read a bunch of posts on fluting and watched some of the referenced youtube videos.
I just can't seem to visualize what needs to be achieved from fluting. If you look at the below pic, when I lay the HS rib web flat on the bench it sits significantly raised up on both sides. To me this looks like it's due to the center of the web being bent a bit which I could reverse by bending at mid web in the opposite direction.
Or is the goal just to get each section of flange fluted so the web underlying just that particular flange lays flat, and not necessarily the whole rib web laying flat all at once.
Really confused here so thanks so much for any help!
