VAF Forums
VAF Forums (http://www.vansairforce.com/community/index.php)
-   RV General Discussion/News (http://www.vansairforce.com/community/forumdisplay.php?f=2)
-   -   Proposed AD for Superior Crankshafts (http://www.vansairforce.com/community/showthread.php?t=179547)
John RV8 02-14-2020 04:35 PM
Looks like the FAA is considering an AD on ALL Superior IO-360 and O-360 Crankshafts.
DEPARTMENT OF TRANSPORTATION
Federal Aviation Administration
14 CFR Part 39
[Docket No. FAA–2018–1077; Product Identifier 2018–NE–40–AD]
RIN 2120–AA64
Airworthiness Directives; Superior Air Parts, Inc. (SAP) Engines and Lycoming Engines Reciprocating Engines With a Certain SAP Crankshaft Assembly
AGENCY: Federal Aviation Administration (FAA), DOT.
ACTION: Notice of proposed rulemaking (NPRM)
The Comment period ends March 16 th.
Tandem46 02-14-2020 04:53 PM
It’s not “all”. It’s ones with “a certain SAP crankshaft assembly installed“.
John RV8 02-14-2020 05:02 PM
AD
If you read the actual proposed AD, In the body of the AD it says ALL, SAP (Superior Air Parts) IO-360 and O-360 engines.
I think the ones with “a certain SAP crankshaft” are a few Lycoming engines which have a Superior crankshaft installed as a replacement.
I hope I’m wrong.
Steve Melton 02-14-2020 06:45 PM
it may be my limited observation, but it seems there are more AD's on 360 than 320 overall.
Tandem46 02-14-2020 06:46 PM
John, it does say “ALL” but it also says “AND”. Here is the entire sentence:
The FAA proposes to adopt a new airworthiness directive (AD) for all SAP Model IO-360-series and O-360-series reciprocating engines and certain Lycoming Engines (Lycoming) Model AEIO-360-, IO-360-, and O-360-series reciprocating engines with a certain SAP crankshaft assembly installed.
Breaking it down, all SAP Model IO-360-series and O-360-series reciprocating engines with a certain SAP crankshaft assembly installed AND certain Lycoming Engines (Lycoming) Model AEIO-360-, IO-360-, and O-360-series reciprocating engines with a certain SAP crankshaft assembly installed.
The “with a certain SAP crankshaft assembly installed” belongs to both “all SAP model” and “certain Lycoming engines” and are joined with the “and”.
This becomes obvious if you read further down the AD and see that they are only talking about certain part numbers and certain serial numbers:
This AD applies to the reciprocating engine models identified in paragraphs (c)(1) and (2) of this AD with a Superior Air Parts, Inc. (SAP) crankshaft assembly, part number (P/N) SL36500-A20 or P/N SL36500-A31, with serial numbers 82976-01; 82976-02; SP12-0003 through SP12-0089, inclusive; SP13-0034 through SP13-0150, inclusive; or SP14-0151 through SP14-0202, inclusive; installed.
If that’s not enough, I have a Superior IO-360 built by Aerosport Power. It has an affected P/N crankshaft mentioned above, however the serial number is not one of the affected mentioned above and I am therefore not affected. A true “ALL” would mean I was affected. I confirmed this with a phone call to Aerosport.
thinkn9a 02-14-2020 06:58 PM
FAA says 77 experimental aircraft have one of the crankshafts
Following from proposed AD and related words
The FAA estimates that this proposed AD would affect 115 crankshaft assemblies installed on airplanes of U.S. registry. This cost estimate does not include 77 SAP crankshafts installed on experimental engines since these engines are not included in the applicability of this AD
Tandem46 02-14-2020 07:27 PM
Hmmm, this is weird. AD says it affects 115 crankshafts plus 77 experimental, which adds up to 192. But they list 256 serial numbers?!?
This AD applies to the reciprocating engine models identified in paragraphs (c)(1) and (2) of this AD with a Superior Air Parts, Inc. (SAP) crankshaft assembly, part number (P/N) SL36500-A20 or P/N SL36500-A31, with serial numbers 82976-01; 82976-02; SP12-0003 through SP12-0089, inclusive; SP13-0034 through SP13-0150, inclusive; or SP14-0151 through SP14-0202, inclusive; installed.”
airguy 02-16-2020 05:57 PM
Originally Posted by Tandem46 (Post 1407992)
Hmmm, this is weird. AD says it affects 115 crankshafts plus 77 experimental, which adds up to 192. But they list 256 serial numbers?!?[/i]
Perhaps not all have been installed.
bnt83 02-16-2020 07:25 PM
14 CFR Part 39
RIN 2120–AA64
Does this **** ever end? Seems like every manufacturer finds new ways to screw up making these things.
Makes me think my 52 year old O320 crank is a better bet than a new one.
Smilin' Jack 02-20-2020 06:36 AM
AD superior IO360
Got the news back from Superior that my engines crankshaft is one of the serial numbers listed
They are compiling a list of owners that have called and will notify us when they, Superior, and the FAA decide what how the AD will be applied.
Of the 3 failures I would love to know how many hours on the engines. Were they relatively low time
Any of the planes RV’s. I understand all three made emergency landings.
I do know Superior finally had to settle the RV8 accident with an XP400 engine.
I have about 530 hours have done oul analysis with no problems indicated.
Wait and see🤔
