Walt Shipley
I just started reading up on installing the cooling shroud on the Rotax and the instructions advise to mark the shroud at the four corners (no Problem), and then place the shroud in postion and mark locations of interference. Question, the trim lines are on the shroud, why not just trim close to those lines and quicken the process? What have others done?
Walt Shipley
Walt Shipley
