VAF Forums
VAF Forums (http://www.vansairforce.com/community/index.php)
-   Electrical Systems (http://www.vansairforce.com/community/forumdisplay.php?f=43)
-   -   Dual Headset / LEMO (http://www.vansairforce.com/community/showthread.php?t=174439)
mulde35d 08-18-2019 05:46 PM
Dual Headset / LEMO
I had been debating for a while whether to wire in two LEMO plugs or 1 LEMO and 1 Standard Headset / Microphone Jack. But now am thinking of an alternate approach.
My question is has anyone wired a LEMO Jack and Standard Headset / Microphone jack is parallel. I am thinking of wiring in a LEMO and Standard jack on each side of the aircraft so I could use a dedicated Bose or a standard plug headset. So it would be 2 LEMO's and 2 Standard Jacks for a 2 seat aircraft.
Thoughts? Issues with noise being introduced through this approach?
PNLBLDR 08-18-2019 06:00 PM
Should be OK!
We have wired both in series hundreds of times with success, should not have any issues!
BobTurner 08-18-2019 06:06 PM
Nick, I think you meant ‘parallel’.
Mark H 08-18-2019 06:31 PM
Yes, I wired both Lemo and standard plugs on both sides and I have no issues. I just wired them parallel where I mounted the jacks. You should have no issues.
AviatorJ 08-18-2019 07:52 PM
I wired both. My lemos have some static, my standards do not. I assume something is grounding out properly, just doesn’t bother me enough to troubleshoot at this time.
RV6_flyer 08-18-2019 08:08 PM
The LEMO jacks in parallel with the "standard" jacks is the way Bose recommends it be done in their installation material.
There is a VAF thread about it here.
See page 37 in the Bose A20 manual.
JDA_BTR 08-18-2019 09:07 PM
Parallel works great. Only plug in one or the other; never both!!!
mulde35d 08-19-2019 04:18 AM
Excellent
That’s what I was hoping to hear. Thanks
