I'm on my second manifold pressure sender in less then 70 hr. The last one failed in less then 4 hours. They are both made by Mitchell Instruments part #ISS CAMPESND. When they failed the gauge needle pegs full scale. The line from the engine is from Van's with a restricted firewall fitting. Only thing different from Vans instruction is the line comes from #4 cylinder.
