VAF Forums
VAF Forums (http://www.vansairforce.com/community/index.php)
-   Electronic Ignition Systems (http://www.vansairforce.com/community/forumdisplay.php?f=103)
-   -   Facing a D3000 OH, any new replacement rumors? (http://www.vansairforce.com/community/showthread.php?t=178859)
rjcthree 01-20-2020 05:07 PM
I’m facing a five year D3000 dual mag OH. Are there any new rumors of a dual mag direct replacement, or even an available single EI mag so I can go stand alone on the second? I don’t plan on going to a dual battery setup on this A/C. Google gives me nothing but the 2018 hybrid articles.
Toobuilder 01-20-2020 07:56 PM
Throw a conventional magneto in the hole on the accessory case and do the crank triggered CPI for the other plugs.
hgerhardt 01-20-2020 08:07 PM
Search the archives for a how-to on installing a single mag. It's a certain Bendix mag required.
lr172 01-20-2020 09:18 PM
+1
This is what I would do. Unsure if a single mag can go in that hole though, as I have no experience with those dual mags.
hgerhardt 01-20-2020 10:29 PM
Originally Posted by lr172 (Post 1401850)
....Unsure if a single mag can go in that hole though, as I have no experience with those dual mags.
Again, read the archives. It's been done several times just on VAF.
WingsOnWheels 01-21-2020 12:27 PM
The SDS ignition system has their own backup battery available (small and compact). You could replace with a dual SDS system and be done with Mags all together.
WillG 01-21-2020 01:37 PM
See airtractor8 post - 12-30-2018
H2AD mag
Caveman 01-21-2020 05:24 PM
Originally Posted by rjcthree (Post 1401751)
Iím facing a five year D3000 dual mag OH. Are there any new rumors of a dual mag direct replacement, or even an available single EI mag so I can go stand alone on the second? I donít plan on going to a dual battery setup on this A/C. Google gives me nothing but the 2018 hybrid articles.
Some info in the following thread:
http://www.vansairforce.com/communit...ad.php?t=90425
cardinalflier 01-21-2020 05:58 PM
Install the SDS CPI-2 system. You will love it. Ií ve been running the SDS on my 6 for 7 months. It is great with superb support by Ross. Bruce Estes
rjcthree 01-21-2020 07:14 PM
Frankenmag?
I copied a section of Tractor8ís post below. I commend him for his research and thoroughness in his description.
<start quote> To do this you can just use the old D2000/3000 and permanently ground one side.(you may already have this setup?) OR use a single Bendix 1200 series mag in its place. The impulse coupling variety has the same drive dimensions as the old dual mag but must be setup to turn in the right hand direction.(most of them are left hand rotation but can be easily changed to Right hand). Try part# S4RN-1227 10-349365-6
You will not however be able to use an impulse coupling with this setup ( there is none available with the required amount of Lag in the right hand direction that will suit the 1200 series). You will need to use a drive coupling commonly used on 6 cylinder 1200 series setups with retard breakers. Part # AEL 73000. This coupling uses the same drive cushions and arrangement as the D2000/3000 and will work with the drive gear in the engine.
You have to use the Electronic ignition for starting and will have to setup your ignition switch(s) to ground the mag for starting or you will get kickback if the mag fires at low speed.<end quote>
I personally donít feel great about the frankenmag setup. Oddly, I feel fine with a megajolt/EDIS4, maybe because I have had one running on the bench for a while. I guess my goal or wish list is a self contained emag to plug the hole for one side, and a stand alone for the other. Plan b is to ground one side of the D3000 as suggested and Stand alone the other side. I donít have a lot of under/beh8nd panel room (donít install the glove box!) for much more after the ADS-B install.
