JohnInReno
I have access to a Dynavibe but I can't figure out how much weight to use. So far, it has gone from .32 IPS at 042 degrees to .16 IPS at 126 degrees but I seem to be chasing it with trial and error.
The engine is an IO-320 with a newly overauled whirlwind CS and was previously balanced with weights on the ring gear.
All I can find in the manual is, "A good starting poin is 0.50 grams / IPS."
Is there a spreadsheet to help?
